Tagged: 19.2, General, mechanical, static, structural-and-thermal, structural-mechanics
January 25, 2023 at 7:34 am
FAQ
ParticipantIf one is using standalone license then they can change the network. In case license is drawn via the network then changing the network may result in error like License Server lost. If possible – connect to company network (accessing server via VPN) via Mobile data while starting the analysis and then keeping laptop turned on and then connecting to home network.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
