Licensing
Licensing
Will CFX-4 run on a Windows XP 64-bit platform? Are there any issues?
    • FAQFAQ
      Participant
      CFX-4.4 installs and runs on a Windows XP 64-bit platform. You need to use the setup.exe in the cfx4 directory on the installation CD to install the CFX-4 software and the setup.exe in the cygwin directory to install the cygwin software. Exceed and Exceed 3D version 7.0 or 8.0 is also needed. The CFX license manager should also be installed from the CFX-4 installation CD. If you want to use User Fortran you will need a 32-bit compiler for this platform. An appropriate compiler has not been verified or tested.
