June 5, 2023 at 7:05 am
FAQParticipantYplus not showing on fluid side of interface in CFD-Post. It appears this is not available when opening the dat file in CFD-Post, however, it’s available when loading the cdat file.
- Skewness in ANSYS Meshing
