January 25, 2023 at 7:34 am
FAQParticipantImagine you have a cylinder fixed in bottom and being pulled in top. The Poisson effect tends to make the cylinder want to shrink radially. It is prevented from doing so due to the fixed support, which gives a reaction in X in the axisymmetric case. These X forces will be canceled out when you consider the whole 360 degrees model. In 2D axisymmetric model, X direction is the radial direction in a cylindrical coordinate system and it’s direction is changing from 0 to 360 degrees. In 3D model, X direction is in Cartesian coordinate system and is fixed. For this reason, force reactions in X are not directly comparble in 2D axisymmetric and 3D full models. In 3D model you may create a local cylindrical coordinate system and then scope force reaction in the cylindrical coordinate system. The X direction will represent radial direction and the value should be the same as in the 2D model.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
