Why while using EDM model, using TUI /define/models/species> species transport expert Minimum cell temperature does not work?
- species transport expert Minimum cell temperature does not work?" target="_blank" rel="nofollow" title="LinkedIn">
- species transport expert Minimum cell temperature does not work?" target="_blank" rel="nofollow" title="whatsapp">
- species transport expert Minimum cell temperature does not work?" target="_blank" rel="nofollow" title="reddit">
- species transport expert Minimum cell temperature does not work?" target="_blank" rel="nofollow" title="facebook">
June 6, 2022 at 8:33 am
FAQParticipantOnly kinetics calculations are suppressed by this control. EDM Turbulent rates will still be non-zero. To prevent burn-back, run a combination of Finite Rate and EDM in conjunction with this control. The minimum rate at lower temperatures wll typically be the Chemical rate; this will be applied and then curbed by the expert parameter.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
