January 25, 2023 at 7:34 am
FAQ
ParticipantNeed to change Default option of Radiosity solver to Iterative Gauss Siedel method for invoking Distributed Memory.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
