March 17, 2023 at 1:11 pm
Solution
ParticipantSee the presentation attached to this solution. Note this was originally presented as a Webinar in French. The Webex recording can be viewed at https://ansys.webex.com/ansys-fr/lsr.php?RCID=695f5a2a4142465ba692b25a5266718c The original presentation in English is also attached.
1. 2042568.pdf
