Why the monitors were not available when right-clicking the Solution cell in WB > selecting “Show solution monitoring”?
- selecting “Show solution monitoring”?" target="_blank" rel="nofollow" title="LinkedIn">
- selecting “Show solution monitoring”?" target="_blank" rel="nofollow" title="whatsapp">
- selecting “Show solution monitoring”?" target="_blank" rel="nofollow" title="reddit">
- selecting “Show solution monitoring”?" target="_blank" rel="nofollow" title="facebook">
Tagged: 17.2, fluent, fluent-post-processing, fluid-dynamics, workbench
June 5, 2023 at 7:05 am
FAQParticipantThe reason is because solution monitoring is only updated when the solution cell is updated from Workbench. If the calculation is initiated in the Fluent window, solution monitors will not be shown.
- Skewness in ANSYS Meshing
