Why the following error appears when try to mesh a crack. “Mesher failed to generate crack meshing. Mesher failed to insert crack meshing. The crack might be outside of the inserting surface, please check the crack definition.”
Tagged: 17.2, mechanical, meshing, modeling-and-meshing, structural-mechanics
January 25, 2023 at 7:34 am
FAQ
ParticipantFor semi-eliptical cracks and arbitrary cracks, the base mesh must be comprised of quadratic tetrahedra. If the hexahedral mesh method is used, or if linear elements are in the buffer zone to the crack, crack meshing will fail. More information can be found in ANSYS Help, on section help/wb_sim/ds_fracture_limits.html.
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
