Why the deformation on the body with a spring connection (body-ground) with a preload is less compared to directly applied force ?
Tagged: 18.1, General, mechanical, static, structural-and-thermal, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantIf the spring is set to rigid behaviour then it changes the stiffness. Make sure that for the mobile in the details of the spring you have the body behavior set to deformable.
