Why sometimes I see differences in the force reactions at the contact interface in ANSYS Mechanical and Mechanical APDL? ANSYS Mechanical contact reactions match with the fsum,rsys,cont option.
April 5, 2023 at 2:33 pm
FAQParticipantThe difference may occur due to different options available in fsum command. Please go through APDL Help document for more information related to fsum command options.
