Why is there a discrepancy between the sign convention for beam shear force plots and those given in standard literature? The moment diagram appears to be consistent, but not the shear diagram.
March 17, 2023 at 9:00 am
FAQParticipantThe shear forces are output in the element coordinate systems. They need to be interpreted with respect to the the element systems.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
