Why is the max. plastic increment is in the sub-step immediately after re-meshing using NLAD is exceeding the default limit of 15%?
March 17, 2023 at 9:00 am
FAQParticipantThe limit on max. plastic increment in a sub-step is not imposed in the first sub-step after a re-mesh happens. This is left intentionally in the code to avoid numerical difficulties. However, it must be honored for the subsequent sub-steps.
