Why is the deformation on the body with a Spring connection (body-ground) with a preload less compared to the case of directly applying a force ?
June 6, 2022 at 9:58 am
FAQParticipantIf the spring is set to rigid behaviour then it changes the stiffness. Make sure that, for the Mobile option in the Details of the spring, you have the body behavior set to deformable.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
