Why is SpaceClaim unable to open a supported third party CAD model and give the error “Failed to attach”?
June 6, 2022 at 9:58 am
FAQParticipantIt may happen that SpaceClaim is not able to read the model when the Workbench plugin is configured. To read the model in SpaceClaim, enable the SpaceClaim Reader. In the SpaceClaim window go to “Application Menu > Spaceclaim Options > File Options > Workbench”. Check the box next to the option “Always use SpaceClaim reader”
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
