General
General
Why is my result not in agreement with Poiseuille Flow?
    • FAQFAQ
      Participant
      Make sure your flow satisfies the following requirements: – 1) Make sure you are getting pressure drop from static pressures (note that Fluent prescribes total pressure at pressure inlets). 2) If you are using a pressure inlet, then this means your flow is developing. Poiseuille flow will only be valid in developed regions. 3) The flow must be laminar.
