Why is initial distance between general edge-edge contact (vis GCGEN) on shell element perimeters always reported as a “gap” even when the shell edges are actually penetrating?
April 5, 2023 at 2:33 pm
FAQParticipantThis is a code limitation. Code cannot distinguish between gaps and penetrations at the start of the analysis. To get edge-edge contact (via GCGEN,,,2) to work in such applications, make sure there is a real “gap” at start of analysis. Zero gap or small penetration will not work, regardless of pinball.
