June 5, 2023 at 7:06 am
FAQ
ParticipantStarting with Fluent 18.2, the serial version is replaced by a parallel structure. If you revert to the serial behaviour by specifying 0 compute nodes for Fluent Meshing but a larger number for Fluent Solver, Fluent Meshing will use the larger number. Set the number of processes for both to 0 to use a version that is similar to the old serial version. Note that this version will be discontinued in future versions of Fluent and Fluent Meshing.
- Skewness in ANSYS Meshing
