June 6, 2022 at 10:33 am
FAQ
ParticipantThe SpaceClaim Combine Tool can fail if the Combine operation will result in one or more bodies that will be very small compared to the overall scale of the model. One workaround is to try the Overlap Bodies Tool under the Workbench tab. This will often work to perform the necessary intersections. You can then manually discard excess bodies.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS DesignModeler: Weld Feature
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- How to move component within the assembly?
- ANSYS SpaceClaim: Imprinting Geometry
- ANSYS SpaceClaim: Shared Topology
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
