Why in Workbench can I not see the option to enable the import of line bodies in the ‘Geometry Cell’ properties?
June 6, 2022 at 9:58 am
FAQParticipantThe option to enable the line bodies import in the Workbench is shown before attaching or importing the model into the ‘Geometry’ cell. To enable this option, add a new analysis system or Geometry component in Workbench.
- ANSYS Mechanical: Node Merge
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- ANSYS Mechanical: Node Move
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
