Why don’t iterations stop after console shows “report defition is converged” for all the criterias active?
June 6, 2022 at 8:32 am
FAQ
ParticipantIf convergence condtion is set as “All the conditions are met”, then even after console shows “report defition is converged” for all the criterias active, iteration does not stop. If condition is set as “Any condition is Met”, then it works properly and stops iteration. Please make sure that your convergence by residual is active. Once it is active, you will see iterations are stopped after convergence is achieved.
- Skewness in ANSYS Meshing
