Tagged: 17.2, FLUENT Meshing/Tgrid, fluid-dynamics, General
June 5, 2023 at 7:05 am
FAQParticipantThe prism mesh may not have the height specified by the window. By default, the Allow Shrinkage option in Prism Growth Options – Proximity Option is turned on. If a proximity point with a narrow gap is detected, then the prism will be shrunk to avoid collision. If you do not want automatic shrinking, please turn off the option.
- Skewness in ANSYS Meshing
