Tagged: 2019 R1, fluent, fluent-post-processing, fluid-dynamics, post-processing
March 17, 2023 at 8:59 am
FAQ
ParticipantThe Mach number contour is based on the cell data whereas the velocity contour data is based on nodal values (when nodal values are selected). To observe a consistency between both contour plots, disable ‘nodal values’ so that both quantities are plotted using cell data.
- Skewness in ANSYS Meshing
