Why does the following error message appear: Syntax error: load parameters should have the format: param=value?
Tagged: 16, cfx, fluid-dynamics, General, General - CFX
March 17, 2023 at 8:58 am
FAQParticipantThis error message is caused by the presence of one or more commas in the name of the file being opened or in the directory in which the file resides. The solution is to check the complete path and re-name any files or directories that contain commas.
- Skewness in ANSYS Meshing
