Tagged: 2019 R1, fluent, fluid-dynamics, General - FLUENT, udf
March 17, 2023 at 8:58 am
FAQ
ParticipantYou get the compiler warning ‘C2065’ ‘undeclared identifier’ if you use a variable before declaring it and if you declare variables at different locations within your code. Fluent expects the code to be written in the C90 standard which is also called ANSI C. According to this standard, all variables must be declared at the beginning of a function. They may not be declared later within a block. These rules were removed in later versions of C. Although Fluent adds the ansi flag to the makefile, it depends on the compiler if this flag is evaluated correctly. Keywords: UDF; user-defined function; user defined functions; compiler; compiled; C2065; undeclared identifier
- Skewness in ANSYS Meshing
