Tagged: 19.1, Adjoint Solvers, fluent, Fluent Flow Optimization, fluid-dynamics, General
April 5, 2023 at 2:32 pm
FAQParticipantIf the following adjoint solver residuals are shown: Computing the adjoint for observable myObservable Iter Adjoint-continuity Adjoint-xMom Adjoint-yMom Adjoint-zMom Adjoint-Flowrate Adjoint-energy 1 -nan 0.00000e+00 0.00000e+00 0.00000e+00 0.00000e+00 0.00000e+00 Invalid arithmetic operations – exiting. ! Adjoint solution is converged then you have probably applied non-constant material properties. Only the density can be defined as either a constant or a compressible ideal gas. All other fluid properties should be defined as constant.
- Skewness in ANSYS Meshing
