Why does tapered BEAM188 model give the message: Element integration point is located outside of end stations. Please verify section input .
April 5, 2023 at 2:31 pm
FAQ
ParticipantTapered beams have to lie on a line between the sections used to define the taper. List tapered section and see the element nodes. Nodes on one element don’t lie between these two points. Admittedly, this requirement makes it difficult to define curved tapered beams.
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
