Why does radiosity between bodies (created with Commands Object) seem incorrect when contact is used but correct when multibody parts are used?
March 17, 2023 at 9:00 am
FAQParticipantWhen Mechanical detects linear contact, it sets NEQIT,1, which is not sufficient to converge the radiosity solution. If you add NEQIT,5 to your Commands Object, it will give good results with contact.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
