Tagged: 2019 R1, 2019R1, fluent, fluid-dynamics, General - FLUENT
March 17, 2023 at 8:59 am
FAQParticipantThe issue is connected to a defect in Fluent 2019R1 where a null residual condition was registerd as unconverged. The solver would keep checking the convergence of that residual even afterl other convergence criteria are met. As a workaround set 1 ( or any large number) for the residual absolute criteria so that residual convergence is correctly verified and always occurs before the convergence of other monitored quantities.
- Skewness in ANSYS Meshing
