June 6, 2022 at 9:58 am
FAQParticipantThat message is generated when lower-order, linear, SOLID185 elements are collapsed into degenerated wedge elements. Degenerated linear shape functions can be less accurate than the full linear shape functions, particularly in areas with high stress gradients. The message is just a warning to identify that the model contains some degenerated wedge elements. The user needs to assess the effect of the degenerated wedge elements on the solution. The message can be eliminated by replacing the SOLID185 elements with higher-order, quadratic, SOLID186 elements.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
