Tagged: 2020 R1, Expiry, FLUENT - SYS, Installation/Licensing/Systems, licensing, Other, warning
January 25, 2023 at 7:28 am
FAQParticipantThis warning will occur if you have any permanent licenses in your license file. Fluent should still continue to be able to use the license, as long as the TECS expiry date is after the build date of Fluent 2020.
