Why does convergence with the EDM combustion model become poorer when changing turbulence models from k-epsilon to SST?
Tagged: 16, cfx, Eddy Dissipation, fluid-dynamics, Reacting Flows, Species/Reactions
March 17, 2023 at 8:59 am
FAQParticipantIn the EDM model, the source term is proportional to epsilon. Switching to the SST model, the rate becomes proportional to omega in the region near the wall. Due to turbulence modelling, omega can have very high values and make convergence more difficult. To avoid this, activate the Mixing Rate Limiter under ->Domain->Fluid Models -> Combustion Models->Mixing Rate Limit. The default value is 2500 [s^-1]. This is a good value for gas combustion.
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
