Why does Contact stiffness (Normal and/or Tangential) reported in Contact Tool not match what is reported in Results Tracker?
March 17, 2023 at 9:00 am
FAQ
ParticipantAssuming the contact tool is under the Model branch, it would be an initial value. The tracker should be after first iteration. With NLGEOM, off, we are probably solving in one iteration (NEQIT,1). With NLGEOM,on, it is probably multiple iterations. Do they match if you turn off stiffness updating scheme?
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
