Why does ANSYS Fluent report a floating point exception at the first iteration when working with the non-equilibrium thermal model for porous cell zones (NETM)?
January 25, 2023 at 7:16 am
FAQ
ParticipantThe non-equilibrium thermal model (NETM) for porous zones in ANSYS Fluent requires the porosity to be smaller than 1 which is the default value. If you forget to adjust this value the solution diverges in the first iteration. Fluent also prints a warning after activating the model to remind you that this value must be adjusted.
- Defining heat transfer coefficient (HTC)
- Simulating Battery Pack Cooling System Using Ansys Fluent
- Thermal Analysis of a Radiator Using Ansys Fluent
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- What is the difference between internal and external emissivity?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- How to use Thin Walls with Thermal boundary conditions?
- Where do I enter radiation properties such as emissivity/absorptivity, are there any recommended values for certain surfaces, and where do I find them?
