Why does ANSYS Fluent report a floating point exception at the first iteration when working with the non-equilibrium thermal model for porous cell zones (NETM)?
January 25, 2023 at 7:16 am
FAQParticipantThe non-equilibrium thermal model (NETM) for porous zones in ANSYS Fluent requires the porosity to be smaller than 1 which is the default value. If you forget to adjust this value the solution diverges in the first iteration. Fluent also prints a warning after activating the model to remind you that this value must be adjusted.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
