Why does activation of Nonlinear Adaptive Meshing (NLAD) cause model to take a different convergence path even before remeshing occurs?
Tagged: 19.2, mechanical, meshing, modeling-and-meshing, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantNLAD does not support auto-asymmetric contact behavior or small sliding algorithm. Hence, if model includes symmetric nonlinear pairs, it is possible that auto-asymmetric is deactivating the current pair when NLAD is off, but keeping both pairs when NLAD is on. Also, perhaps small sliding is active when NLAD is off, but it is disabled with NLAD is active. The solve.out file should record these setting. Check the solve.out file carefully.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
