March 17, 2023 at 9:00 am
FAQParticipantThe default SHELL181 applies inertial forces at the nodes without the associated moment. Ignoring rotational inertia could cause hour-glassing with this formulation. Setting KEYOPT(3)=2 corrects the problem. This behavior has been documented in the limitations section for SHELL181 element documentation.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
