March 17, 2023 at 9:00 amFAQParticipant
The redundant axial constraints prevent the beam from compressing or elongating. For a beam with an offset, this prevents rotation, and even though the beam is simply supported, the redundant constraints allow large end moments to develop. You may notice in the results that the SDIR value in the beam is, for example, around 12,000 psi. The eccentricity of that 25,000-lb axial force from the neutral axis produces an end moment that reduce the moment at the applied load.
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- Structural modeling with ANSYS Workbench Mechanical
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- What is the difference between shell 63 and shell 181?
- What might cause the “Error: HResult E_Fail has been returned from a call to a COM component” in SpaceClaim?
- Why would I get non-zero force reaction in X direction in 2D axisymmetric model?
