Why do not I have the button ‘Show contact’ in the prepare tab of SCDM R18.1 while it is available in R18.0?
June 5, 2023 at 7:05 am
FAQParticipantThe sharing toppology has been ‘re-designed’. There is a new tab called ‘Workbench’. After sharing the topology between bodies, you can display the shared topology in the option ‘Display’.
- Skewness in ANSYS Meshing
