Why do I get the following error when running System Coupling with CFX from the command line? +——————————————————————–+ | Warning! | | | | Output call terminated unexpectedly: Aborting due to internal | | error: “CFX5::Output::CCL=HASH(0x26e89a8) There is already a | | definition file, refusing to create a new one”. | +——————————————————————–+
Tagged: 2019 R2, fluid-dynamics, General, system-coupling
June 5, 2023 at 7:06 am
FAQParticipantThis error is caused by the presence of the *.dir folder from an old run in the run directory that also contains the .def
- Skewness in ANSYS Meshing
