Why do I get the error ‘Error: Failed locating standalone Icepak installation. Please set AWP_ROOT202 environment variable to the versioned directory in the install.’ when running Icepak within SIwave?
March 17, 2023 at 9:00 am
FAQParticipantFor SIwave 2020R2 and earlier versions, an Icepak Classic installation from the Fluids installation package is required to start the Icepak solver. Make sure this is installed. The env var mentioned in the error message will be set. Verify this in the system environment variables. Its value will be the install folder (AWP_ROOT202 = C:Program FilesANSYS Incv202). As from SIwave 2021.1, the Fluent solver will be launched from the ANSYS AEDT installation, thus an Icepak Classic installation will not be required.
