Tagged: 18.2, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantStarting with Fluent 18.2, a parallel architecture is used for the serial version, too. This means that several TCP/IP ports are required for communication between the different Fluent processes and for error handling. Port conflicts with other programs are handled automatically and provoke warning messages like 428: mpt_accept: warning: incorrect exercise message “GET /” from 10.1.0.188 on port 56564 Typically, you can ignore such warning messages.
- Skewness in ANSYS Meshing
