April 5, 2023 at 2:33 pm
FAQParticipantIf a sketch used for the skin/loft profile(s) is over-constrained, you will see this warning. Remove one of the constraints and regenerate the skin in the tree, and the yellow check mark will turn green.
- Skewness in ANSYS Meshing
