Why do I frequently get energy imbalance when I use shell conduction, even if my calculation looks well converged (stable monitors and low residuals)?
January 25, 2023 at 7:16 am
FAQParticipantHeat flux at the sides of the shell walls are not taken into account inside the heat flux reports in Fluent (> Report > Fluxes > Total Heat Transfer rate). This means that at these locations, heat flux is accounted for correctly in Fluent, but cannot be post-processed. If the heat flux crossing the side faces is significant, this could lead to an imbalance in the reports between the wall and wall-shadow (more than 30% imbalance reported in some cases). To make sure this imbalance is not due to convergence difficulties, a good practice is performing a quick sensitivity analysis by reducing either the shell conduction thickness or the conductivity of the solid material, and then checking changes in the heat flux report accordingly.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
