March 17, 2023 at 1:10 pm
Solution
ParticipantThe HDF libraries used for CGNS export have been updated from 1.08.14 to 1.10.5 in ANSYS Meshing 2021R2. Third-party tools with HDF libraries older than 1.10.5 will not be able to import the files generated in 2021R2. Please read the PDF file attached to get a workaround.
1. 2064874.pdf
2. 2064874.zip
- Skewness in ANSYS Meshing
