Why do DesignModeler versions 2021R2 and 2022R, sometimes stop working, when running on a Windows operating system. Producing the message, Warning: DesignModeler license has expired. All modelling operations will be disabled. You will be able to save your work.
April 13, 2023 at 7:32 am
SolutionParticipantPlease see attached .pdf document for the resolution.
1. 2068136.zip
