Why can`t I use an inert stream in a Fluent adiabatic flamelet calculation? It works for non-adiabatic flamelet calculations, but it is greyed out for adiabatic calculations. Is this a defect?
Tagged: 19, Flamelet Models, fluent, fluid-dynamics, Reactions, species, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantFluent’s inert model can only can be used with non-adiabatic non-premixed or partially premixed combustion model. That is why it is greyed out for the adiabatic case. This option was enabled for the adiabatic case in fluent releases prior to R17.0, but this was a defect. The inert stream affects the solution due to its influence on enthalpy, specific heat, and density of the mixture. Inert calculations therefore require the enthalpy information, H_pdf, that is available in the non-adiabatic PDF tables: H(cell enthalpy) = (1-y_inert)*H_pdf+y_inert*H_inert; For non-adiabatic case H (left hand side) is known and H_pdf is also known from mean mixture fraction, we calculate the temperature, then calculate H_inert and go back to the above equation iteratively. For the adiabatic case, the cell enthalpy is function of mean mixture fraction only. The above equation can still be attempted with H(cell) calculated from Fmean, but H_pdf could only be calculated using a modified_fmean that is a function of y_ inert. This would indirectly make the above equation iterative over y_inert, which is not desirable as y_inert is to be solved for.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
