June 6, 2022 at 10:33 am
FAQ
ParticipantPlease check if you have applied any Assembly constraints under the “Design Tab” on your Components in SpaceClaim. If there are any Assembly Constraints like Align, Rigid, Tangent, etc, it may restrict the movement of the parts depending on the applied constraint. To move the Component using the “Move” command, you will have to remove the Assembly constraint accordingly.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Create Sections in Meshing
- ANSYS ICEM CFD: Basic Blocking
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is meaning of message: One or more objects may have lost some scoping attachments during the geometry update.
- What is the difference between patch dependent meshing and patch independent meshing?
