Why can AnsysEDT 7 Nexxim not simulate a Spar file and exits with parser error, although it can be opened in Networ data explorer ?
Tagged: 16, All, Circuit designer, Designer, Electromagnetics & Electronics, system
May 25, 2023 at 7:29 am
FAQParticipantThe parser error appears, as the path is too long pointing to the Spar file itself (> 64 charactes, in this case 7 directory levels). Generate flat hirachacy and reimporting the S-par file, the LNA simulation runs without errors
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- How to Set “Non-Model” Property to an Object in 3D Layout
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- How to Create Bondwires in 3D Layout ?
