Tagged: 18.2, contact, General, mechanical, structural, structural-and-thermal, structural-mechanics, thermal
June 5, 2023 at 7:05 am
FAQParticipantIf there is a small gap in the contact, this could make the parts in the contact fly apart when the contact status is open. It is suggested to add offset value in the contact with the option ‘Add Offset, No Ramping’ or use ‘Adjust to touch’ option. If you check the initial contact information, you can get initial gap value. Which you can input as offset in the contact.
